Showing results for tags '...for best TV experience'.
Found 1 result
  1. Hello, I'm using a LG smart TV with webos (and previuosly a Netcast TV) and I think there are some simple changes to do that can improve a lot the overall TV esperience (not Smart capabilities). Please add your thoughts or your suggestion in order to have a complete list of simple improvements. I'll add them in this first post to have a complete list of changes. 1) When using remote command numbers, the reaction of the TV seems very slow. It needs to be improved. I think it is related to the searching of most recent channels that starts with pressed number/s. If this is the reason, ---> I suggest an option to enable/disable that search (when a number is pressed on remote command) to improve response time. 2) Settings menu is very attrative, but it is damn slow, above all at first opening. It can be right for some settings rarely used, but there are settings that needs to be very fast to use, as "aspect ratio". In Netcast environment, there was a button to modify aspect ratio directly. ---> I suggest an option to associate a shortcut to a color button (if needed, an option in menu to enable/disable this shortcut). ---> A more general suggestion is the possibility to associate custom function to color buttons choosen by user: this'd be the best. 3) One of the most confortable thing of Netcast was that the channel short info (showed by OK button) was showed automatically when the channel is turned. ---> I suggest an option to associate show/not_show the OK info on TV when a new channel is selected. 4) First pressure on Info button is useless, while second pressure shows details. ---> I suggest an option to associate enable/disable INFO first pressure information on screen, to avoid second pressure that shows an annoyng lag. More suggestions soon...
