Showing results for tags 'arabic subtitle webos unicode'.
Found 1 result
  1. the problem with WebOS Arabic Subtitle is that you have to change the encoding for each movie when you first play it not only that but also if the encoding is UNICODE the subtitle will not be understandable. the mentioned problems didn't existed before in the older platform. it is not accepted to have this "faux-pas" while all electronics manufacturers plan for improvements LG did a huge mistake using the WebOS. the main purpose for buying a smart TV is to benefit from its internet access and movie playing and this is not achieved with LG WebOS TV. i am not sure if this is the correct place to emphasize my problem... but i need solutions hope any LG Customer service support can contact me.
