Showing results for tags 'audio input'.
Found 3 results
  1. I have a 65 Inch LG OLED evo AI C4 4K Smart TV 2024 - Model OLED65C4PUA.ACC. here have been a many weird things happening. This is one of them: Whenever I turn on my TV, it doesn't remember the audio settings I chose before. I repeatedly need to set my audio for the input I am using. I ofter select APPLY TO ALL INPUTS to try and make sure it's the same regardless of which input I use, but it still reverts all changes. Does anyone know what this happens?
  2. Hi all, new TV owner, I bought the 55 inch UM7400 and have it connected to a Sonos Beam with two Play 1's for surround. I have a turntable plugged into the stereo RCA input of the TV to get audio through the soundbar which is excellent, only one problem - the TV obviously does not receive any picture signal and therefore switches itself off after about 20 minutes! I have emailed this problem to LG but I find I have to explain the problem to every tech that replies with a basic menu fix (no, changing the Deep Colour setting is not going to fix this problem...!) All the settings that relate to timer/screensaver/energy saving so not seem to be affecting this. Does anyone else have a similar setup (turntable>TV>soundbar) and have a fix to keep the TV from going to sleep? Cheers!
  3. I have a UK6090PUA 55" SmartTV. All firmware and WebOS software and is up to date. I have connected a Roku 2 and LG BP-M25 Bluray/DVD player to HDMI ports 1 and 2. I get an audio pop whenever content play starts on both the Roku and DVD player. If I use the WebOS apps there is no pop. First inkling is that the HDMI connection is the issue. Has anyone experienced this and is there a fix? Honestly I like the Roku streaming apps better than the internal apps. Playback is smoother. While using the internal WebOS Hulu or Prime Video apps I catch an occasional stutter.
