Showing results for tags 'audio output'.
Found 5 results
  1. I have a LG 55" 4K UHD HDR OLED webOS Smart TV and a Sonos Arc. They have been working together fine, but suddenly are not and I cannot seem to fix it. I have tried everything from new hdmi cable to total factory reset on both pieces of equipment and I am so frustrated! Can anyone assist me with what might work? Or is anyone else suddenly experiencing issues with this setup as well? thanks!!
  2. Hi everyone, I’ve recently bought an LG OLED65BX6LB and have connected a Sonos beam using the HMDI arc port. When I try to play the sound through an alternative output eg Bluetooth or the internal speakers it does so for a couple of seconds and then it switches back to HDMI-ARC How do we stop the HDMI ARC grabbing control?
  3. Hey y'all, I've been having a hell of a time getting sound to come out of my edifier R1280T bookshelf speakers. For reference, they are connected via component cable (RCA to RCA I believe?) and I had no problem changing sound output on my last TV to come out of them. So I looked up a few videos and they suggest going to "Device Connector" and setting up the appropriate device (soundbar, home theatre, external speakers, etc.)/ The problem is, when I go under "external speakers/headphones" the only option I'm given is bluetooth! I see a component (or AV) option when I choose "Home Theatre" but when I continue to the next step for audio, my only options are HDMI or Optical . Is there a way I can connect these speakers with this TV or am I out of luck? Attached a picture of the screen that is giving me such trouble.
  4. I have a hearing loss and would like to listen to the TV through my Bluetooth headset while at the same time others in the room listen normally via sound bar. We have a Samsung 2.1 sound bar/sub that is controlled through the LG TV via HDMI. I also have a BT transmitter that has an optical audio-in that is paired with my BT headset, but the TV only lets me use one output method at a time. I would like to find a way to use both HDMI-out and optical audio-out at the same time. If the sound bar had an audio-out port on it, I would use that - but it does not. The TV model is an LG 55lb7200.
  5. Hi, I bought a 47 inch 650V TV a week ago and I noticed that this SmarTV has a huge potential but still lacks very basic features. So I hope that I don't regret buying this TV if a update don't gives us some really great improvements. * First of all, WebOS it's slow. It really needs a huge performance improvement. Im not a BETA tester. If the system it's not ready, they should have hold it for a while and hire some inside beta testers. * Youtube app doesn't play videos in HD. Compared to my AppleTV, the difference it's huge. This is a 1080p SmartTV and there's not a single option on Youtube to play everything in 1080p or at least, 720p. * Audio Output only gives us a option to select one instead of a multiple sound output. Sometimes I use a Digital Out Surround Systems, and in my old LG TV, I could use the TV Speakers and this digital audio at the same time and only mute the TV. It's the fastest way to use both. In this new smartv, I have go to the audio settings to choose the audio output everytime. For a slow system, it's a really painful solution. * This TV has Bluetooth built in, and there's not a single option to pair a Keyboard, Mouse or a Audio Device. It's locked to LGs proprietary Bluetooth devices. It's inaceptable since Bluetooth technology is standard and to use a Bluetooth Keyboard/Mouse/A2DP sound I have to get a pack that cames with a USB Bluetooth dongle. So all my BT keyboards and mouses that doesn't have that USB dongle can't be used. * I own a LG G2 Smartphone and I cannot simple use the LG SmartShare. It's slow and crashes all the time, so sharing my videos and photos to TV it's simple mission impossible. The same goes for Wi-fi Direct. It simply doesn't work. And the same goes for the LG TV Remote App. It's very slow when we try to use the "mouse pointer". * It's not possible to resize .srt subtitles and tags like <i> and <b> are not recognized by the TV. So not only I can't have Italic and Bold text, but those tags are also added to the subtitles like normal text... And I notice this with just one week of usage, so obviously there's a lot more things to improve but this features are simple to use on my AppleTV and my LG can't handle them very well. I bought this TV and paid the extra money to get a good SmarTV compared to the 5700 model, with the intention to get rid off the Apple TV... but at this moment I just can't...
