Showing results for tags 'change region'.
Found 1 result
  1. Hello all, After reading many forums how to change region for LG smart TV using Ez-Adjust I gave up. I am trying to change my reading from IL to US (area code 1793), all forums say the same thing, go to Ez-Adjust->Area Option and change the id in the first line to the US ID. I tried it but there is no way to change the current ID, I type the US id but nothing change, In addition I tried to change it through IN START but nothing, i was unable to change region. I hope there is someone here that had the same problem and solved it and can help me. I will appreciate any help. Thanks.
