Showing results for tags 'dolby vision'.
I've LG GX OLED which is the best tv in market yet it doesn't stream 4k HDR content in Disney plus hotstar.... But in all other platforms Disney plus hotstar is streaming 4k HDR content... Why not on WebOS.....? By the way I've Disney plus hotstar premium subscription waste of money for taking that...
- 3 replies
- hotstar app premium
- hdr update
- (and 6 more)
When I try to play some Dolby Vision video on my OLED55C6V from USB-flash or from DLNA-server (without any conversion) by the internal application for photo and video playback I see the picture painted green. Some Dolby Vision video is played properly. So can I change something in my television settings or in the video-file (I would be able to re-encode or remuxe it if I knew what should I change) for fixing the problem? Thank you beforehand! Mediainfo file dump: General Complete name : N:\02.Chameleon.mp4 Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (mp42/iso6/isom/msdh/dby1) File size : 530 MiB Duration : 1 min 2 s Overall bit rate : 70.9 Mb/s Encoded date : UTC 2019-06-13 18:12:29 Tagged date : UTC 2019-06-13 18:12:29 Video #1 ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main [email protected]@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : hev1 Codec ID/Info : High Efficiency Video Coding Duration : 1 min 2 s Bit rate : 55.6 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.280 Stream size : 416 MiB (78%) Default : No Encoded date : UTC 2019-06-13 18:12:29 Tagged date : UTC 2019-06-13 18:12:29 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Maximum Content Light Level : 1000 cd/m2 Maximum Frame-Average Light Level : 60 cd/m2 Codec configuration box : hvcC Video #2 ID : 2 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main [email protected]@High HDR format : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible Codec ID : dvhe Codec ID/Info : High Efficiency Video Coding with Dolby Vision Duration : 1 min 2 s Bit rate : 13.6 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.274 Stream size : 102 MiB (19%) Default : No Encoded date : UTC 2019-06-13 18:12:29 Tagged date : UTC 2019-06-13 18:12:29 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Codec configuration box : hvcC+dvcC Audio ID : 3 Format : E-AC-3 JOC Format/Info : Enhanced AC-3 with Joint Object Coding Commercial name : Dolby Digital Plus with Dolby Atmos Format profile : Blu-ray Disc Codec ID : ac-3 Duration : 1 min 2 s Bit rate mode : Constant Bit rate : 1 664 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 16 bits Compression mode : Lossy Stream size : 12.5 MiB (2%) Language : Russian Service kind : Complete Main Default : No Encoded date : UTC 2019-06-13 18:12:29 Tagged date : UTC 2019-06-13 18:12:29 Complexity index : Not present / 16 Number of dynamic objects : 15 Bed channel count : 1 channel Bed channel configuration : LFE
