Showing results for tags 'dual audio'.
Found 2 results
  1. I have a hearing loss and would like to listen to the TV through my Bluetooth headset while at the same time others in the room listen normally via sound bar. We have a Samsung 2.1 sound bar/sub that is controlled through the LG TV via HDMI. I also have a BT transmitter that has an optical audio-in that is paired with my BT headset, but the TV only lets me use one output method at a time. I would like to find a way to use both HDMI-out and optical audio-out at the same time. If the sound bar had an audio-out port on it, I would use that - but it does not. The TV model is an LG 55lb7200.
  2. Hi, I am having 42LF6500 TV, When i use input as USB and the video is having dual audio stream, Please anybody can suggest how to change the audio stream according to convenience? Regard, Manoranjan
