Showing results for tags 'external hdd'.
OK. I have a 2018 LG Smart TV model OLED65C8PUA. The TV 'magically' recognizes and (badly) displays/ plays the 2gb of photos, videos and audio residing on my Western Digital 4TB My Passport external hard drive I have. The problem is the TV is the ONLY device that WILL RECONIZE THE DRV! 8 diffirent computers running from Vista to Win 10 have given me 'DRV (x) is not accessable'. At one time the drv was password protected and it worked fine. The exact password was lost so I tried a number of variations and was able to finally unlock the drv and remove the password using WD Utilities. It worked for a bit and I was able to copy out a few files using a Surface Pro/ Windows 10 but it stopped and now with that Surface Pro and the other windows machines I get `D is not accessible. The parameter is incorrect'. I even put it on a Samsung smart TV - none will read the drv, ONLY THE LG! The LG also displays the DRV'S volume label and content filenames as well. I want to copy these files before the drive fails as the catch here is the LG seems to produce one or two "unrecognized files' every time I use it and some of these videos are one-of family heirlooms! I want to avoid another $300 data recovery bill if possible. And if the LG can read it one would think there is a way forward. Any suggestions will be most appreciated!
Connect external drive to TV over network
Rukmaj Chandavar posted a question in LG webOS Smart TV Questions
Hi All, I recently bought a LG Smart TV with WebOS (42LB6500) and would like to connect to my external hard disk connected over network. Here is how my home network and devices are setup. I have a high speed broadband that comes to my WiFi router (D-Link DSL 2750U) with USB support for External HDD. I have connected my Seagate Ex.HDD to this router and I am able to access the drive over WiFi on my smartphone and computer using the network path \\192.168.1.1\... Once connected I am able to use it similar to any mount location, i.e., read/write files, play media, etc., I want to do similarly with my TV, I would like to use this connected Ex. HDD as any other location and would like to achieve following two things at the least without any additional hardwarePlay media files on this HDD (very very important) Use the HDD as recording device for timeshift/live pause feature (important) Any help in this regard would be greatly appreciated. Regards, Rukmaj- 11 replies
- 1
- WebOS
- External HDD
(and 3 more)
Tagged with:
