Showing results for tags 'ez adjust'.
Found 1 result
  1. It's been noted on various forums that some LG TV owners can change the country code through the ez adjust service menu. For example: http://forums.webosnation.com/lg-webos-tv/328085-hulu-plus-netflix-overseas-lg-webos-tv.html It appears the instructions covered in the link above are for webos 2.0 versions. Changing country code has allowed many users to download apps not available in your own country. A small amount of forums state that some LG TV owners cannot change the country code through the ez adjust service menu. For example: http://mybroadband.co.za/vb/showthread.php/687684-LG-WebOS-TV-s-cannot-change-region-to-get-Netflix-etc?p=15362222&viewfull=1#post15362222 Some of those owners report a different menu, most likely those users NOT using webos 2 and are using webos 1.0 or webos 1.5 In Australia on my TV I see - 7. Country Group Country Group Code 19 Country Group AJ Country -- 8. Area option Area code 263 Wi-fi Frequency 7 Lang Gr. ALL Teletext Lang Gr. W_EU I II Save On HDEV Off MONO Off Location 0 Isolator 0 I found that the South African user posted that they had a similar menu: http://mybroadband.co.za/vb/showthread.php/687684-LG-WebOS-TV-s-cannot-change-region-to-get-Netflix-etc?p=15362222&viewfull=1#post15362222 Comparison between Australian and South African users posting about the issue - Area Option Area Code - South Africa: 259 Australia: 263 Wi-fi frequency - South Africa: 3 Australia: 7 I note that the difference between the Area Code between the two countries (263-259) equals 4. Further, the difference between the Wi-fi frequency between the two countries (7-3) equals 4. I suspect that it is possible to change the country and thereby download apps from another country. I think the USA Area code is 02. Anyone figured out how? Perhaps posting up your Country Group Code and Area Code (IF you have webos 1.x) may be a step towards this process.
