Showing results for tags 'firestick 4k'.
Found 2 results
  1. Hello everyone, Apologies if I'm writing in the wrong forum, this is my first time. I've just bought a LG 55ur80006lj 4K UHD Smart TV, I've got an Amazon Firestick 4K that I'm using with it, when I go to 4K content, sometimes it shows UHD at bottom or sometimes 1080p HDR on it, when I go to settings it mentions, for 4K I require a stable strong internet (which I have) and an HDMI port supporting HDCP 2.2 I wanted to know if the model I have, does it support HDCP 2.2 or not!! Thank you
  2. Hello all I have the as anyone tried using their multi-view feature. I've just discovered that one side Amazon Firestick 4K and the other side just normal air broadcast. I have noticed that with the Amazon Firestick 4K will not let you watch anything on the opposite side you have to uncheck the firestick 4K then you can watch something on the other side. But what's the point because that's the purpose I want to watch both at the same time my firestick 4k and my over the air broadcasting channels. Does anyone have a solution to this problem greatly appreciate it thanks for your help in advance. Note: This Feature work for me with the old Amazon Fire TV stick that is not a 4k. 20190813_180730_1_1.mp4
