Showing results for tags 'google assistant'.
Found 7 results
  1. UPDATE: Tried another approach of setting up by asking Google Assistant on my iPad to "set up my device" - couldn't complete as "something went wrong" and left it at that. The Google assistant app somehow appeared as a new app this week and the button on the magic finally works to activate Google assistant on the TV. Not sure what happened but fingers crossed. ********** Has there been a withdrawal of Google Assistant on LG TVs in Singapore? With language, broadcast country and LG services country set to "Singapore" , pressing the Google Assistant button on the Magic Remote shows a message indicating that the service is not available in my country. My LG account and Google assistant settings for the same account have their location and set up in Singapore too. The only (unsatisfactory) workaround is to control the TV indirectly using either my smartphone or connected Sound Bar which have Google Assistant installed. I've tried switching the region to Australia and I'm able to set up Google Assistant on the TV. But with this I'm of course unable to log into the TV using my LG account given the region difference. How should the set up be done?
  2. Hi, I can turn the Wi-Fi socket on and off using the Google Home app on my mobile phone by using the voice command "turn socket on" and "turn socket off". Using the same commands with Google assistant on the magic remote, will turn the socket on but will not turn it off. Any advice please?
  3. hi, i have a uk6300 webos tv. i baught it becase it said google assistant is available.but what i tried to add voice commands i found that aoogle assistnt, alexa and home dashboard is mising and cant find in the LG store..and it has limited amount of service countries to select. i am in sri lanka and google assistant works in my phone.plas help me to install google assistant and home dashboard on my TV.
  4. I cannot set up my google assistant on LG 7400plb smart tv
  5. LG’s 2018 lineup of AI-enabled ThinQ TVs are going to be getting Google Assistant functionality in many of its international markets. Starting 8/24, Google Assistant will be available in Canada, Australia, and the UK, with support coming to South Korea, Spain, France, and Germany by the end of the year. LG’s ThinQ TVs came with integrated Google Assistant when they launched in the US and added support for Alexa commands soon after. The built-in ThinQ AI, which runs on LG’s own WebOS can be used for TV-specific commands, such as “search for the soundtrack of this movie,” while Google Assistant and Alexa can be used as a smart home hub. You can basically use the TV the same way you’d use your Google Home by speaking commands into the mic on your remote. LG is also planning on bringing Amazon Alexa support to Australia and Canada in the future, but no time is specified yet. Source: https://www.theverge.com/circuitbreaker/2018/8/24/17779468/google-assistant-lg-thinq-tv
  6. Hi, I bought this TV in Israel but it doesn't have the option to set Google Assistant in it, It's running WebOS 4.0 but for some reason LG decided to remove it from the models they sell here. Can I manually install the apps on my tv? Can I install the US firmware instead?
  7. ENGLEWOOD CLIFFS, N.J. May 8, 2018 — LG Electronics USA announced the Google Assistant is launched on its 2018 AI TV line-up. This includes both LG OLED TVs and LG SUPER UHD TVs with ThinQ AI, which will deliver cutting-edge AI features operated directly through the TV’s remote control with no additional hardware required. As previewed at CES® 2018, the collaboration between Google and LG will add more convenience in consumers’ lives, and the synergistic effects expected from this technology partnership will particularly impact LG’s award-winning TVs. Full press release: http://www.lg.com/us/PDF/press-release/LG-TV-Google-Assistant-Launch-Release.pdf LG brings Google Assistant to its 2018 ThinQ TVs powered by webOS Why LG TV’s Google Assistant in 2018 is a big deal
