Showing results for tags 'google home'.
How to connect my LG TV to Google Home Hub?
Santosh Kumar Gupta posted a question in LG webOS Smart TV Questions
Hi there, I have a 32" 32LH604T-TB LG Tv and recently I bought a Google Home Hub. I am not sure if my Tv has Google Assistant built-in but I want to control the TV via Google Home Hub. Unfortunately , I can't find any solutions to connect my Tv to Google Home Hub. So, is there a way to connect this two devices without any other equipment (like Chromecast )? -
Hi, I can turn the Wi-Fi socket on and off using the Google Home app on my mobile phone by using the voice command "turn socket on" and "turn socket off". Using the same commands with Google assistant on the magic remote, will turn the socket on but will not turn it off. Any advice please?
- magic remote
- google home
(and 1 more)
Tagged with:
LG WEBOS 55UK6360 PTE GOOGLE HOME SUPPORT
MinakshiSamvedi posted a question in LG webOS Smart TV Questions
I can't connect my google home hub to my smart tv(UK6360PTE) don't say, it doesn't support it because it has an inbuilt Google assistant and also the model no is mentioned on the LG website containing the list of supported models. It's a 2018 model. The app named "connect tv to Google assistant" is missing from the home screen. I tried to be over smart (LOL) and asked the voice command for the app it said opening the "connect tv to Google assistant" app and redirected me to the app store but it said not available. HELP ME...- 2 replies
- google home
- help
(and 6 more)
Tagged with:
Bîrlă Andrei posted a question in LG webOS Smart TV Questions
Hi there, I have a 50" UK6470PLC LG Tv and recently I bough a Google Home Hub. I now that my Tv has Google Assistant built-in ( accesible only with Magic Remote wich I don't have) and I want to control the TV via Google Home Hub. Unfortunately , I can't find any solutions to connect my Tv to Google Home Hub. So, is there a way to connect this two devices without any other equipemnt (like Chromecast )? Thanks in advance! -
Google home integration compatibility
troy olson posted a question in LG webOS Smart TV App Questions
When will LG add Google home compatibility? Ifttt would also be beneficial.- 4 replies
- 3
- google home
- compatibility
(and 1 more)
Tagged with:
