Showing results for tags 'hard drive'.
Hi I've got an LG Smart TV 43UM 7400PLB and am looking to buy an external hard drive so I can pause live TV and record programs. I'm currently using a much smaller capacity USB which can't pause live TV and will soon be full. I've read on various forums that certain hard drives won't work or that I'll need to buy a certain connecting cable. I was thinking of buying a Seagate 2TB drive, (STGX2000400) which is around £55. Can anyone recommend one or confirm that the Seagate one will be okay. Thanks.
Hi everyone. I have a quite recent LG 43UM74507LA smart TV (2019 model). The current software version is the 05.10.25. I can read on the guide that the maximum suggested size for an external USB-connected drive is 2 TB. But what does it mean suggested? That it might be dangerous in some form for the hard drive to connect a unit which is larger than 2 TB? I am asking this because I actually use to connect a 4 TB external hard drive (a portable WD elements), with single NTFS partition, just to watch some video files (so no recording or else), and it works just perfectly. No problem of any sort. That's why I am very confused. I should also add that this drive is almost full (it contains 3.6 TB of data), and this does not affect the readability by the TV. I am indeed considering to buy another hard disk (exactly because the former one is almost full 😄), and I am considering a 8 TB WD Elements Destkop, which will be also formatted in NTFS (the only difference is that this one must be plugged to power as well, while the former only requires to be plugged to the TV via USB). Now, since the former 4 TB hard drive actually works, despite the "official suggestion", should I be confident that also the 8 TB one will work? Would you suggest me to proceed with buying that? Thank you very much in advance for your answers!
So, it's the year 2018 and all the documentation I have found online says that LG TV's USB storage are limited to a max capacity of 2TB... nowadays that's considered rather small in terms of PVR and play backing of HDR 10bit content. I've ordered a the LG 49sj800v which is due to be delivered in the next couple of weeks so I am in the process of preparing the hard drive ready for it, which I have a WD Red 6TB however after reading it seems to be limited to 2TB?! which surprises me because the TV even has a USB 3.0 port. It is from my understanding that FAT32 is limited to 2TB and NTFS is limited to 16TB which brings me to my question(s): Does the 2TB limitation still apply in WebOS 3.5? if the limitation does still apply is the limitation caused by Hardware or Software? If the limiation does still apply can you use multiple partitions or is the limitation the entire drive? PS. I plan to use NTFS.
- 2 replies
- hard drive
- usb
(and 2 more)
Tagged with:
Hello, I am new to this and would like a little help. I just bought my first telly (LG 49UB8500-ND). I love everything about this telly, I am only hoping to love it more. My family is all Apple computers and iOS deices. However, my hard drives i reformatted to windows so that i can plug them into the telly (one 2TB and one 5TB). I have an apple base station extreme and the telly connects to it (as does any and all devices). I also have one of the hard drives plugged into it. I would like the telly to see the hard drive so that i can play movies that way instead of having to plug the hard drive in every time i want to play a movie or tv show. is it possible?
- 1
- hard drive
- wireless
(and 1 more)
Tagged with:
