Showing results for tags 'hdmi arc'.
I have a NANO91ANA LG TV connected via HDMI to a Yamaha RX-V677 Receiver. Normally when I turn the TV on it also turns the receiver on and I can control volume via the LG remote, whether it is an app on the TV or from another device connected to my receiver (Apple TV or cable box). Now the receiver...
There is a thread about the issue. Please use it instead. TL;DR unplugging and plugging the HDMI cable back to the TV fixes the problem until the TV is turned off. Next time the TV is on I have to repeat this. I have the following setup: TV: LG SK8500PL SW Version: 05.50.10...
HDMI ARC - Keeps shutting off sound bar
Floyd Cordisco posted a question in LG webOS Smart TV Questions
This LG OLED 55A1PUA keeps hutting off the sound bar. Thought it was the sound bar - replaced sound bar and this issue is still here. How do i fix this? Is this a TV issue? -
LG UHD TV digital sound out popping noise problem
Krash01 posted a question in LG webOS Smart TV Questions
Dear Readers,I've a strange issue that I've been struggling for a week. I bought an LG43UJ634V UHD TV and an LG LHB645N Home Theater in a Box system.I use HDMI ARC to connect the audio from the TV to receiver. LG has an option to chose between PCM or Auto at the Digital output settings.If I use the... -
No sound from receiver when using LG cx apps
Blackorchid posted a question in LG webOS Smart TV Questions
No sound coming from av receiver when using apps on LG cx . I have CEC on Integra DRX 3.3 and simplink on the tv turned on. Sound is fine otherwise. -
sound bar sk9y HDMI ARC TV to Sound Bar not working
Jose Antonio Campo posted a question in LG webOS Smart TV Questions
Dear Friends , Really looking forward to your help and support My problem is i can not make work the HDMI ARC conection between TV and Sound Bar So far: TV LG OLED55B7P-S (latest firmware) Sound Bar LG SK9Y (latest firmware) NVidia Shield Pro 2017 (latest firmware in m...
