Showing results for tags 'hp veer'.
Found 4 results
  1. HP Palm Veer 4G P160 GSM Phone, Black & White (Unlocked) http://www.walmart.com/ip/21281000?wmlspartner=wlpa&adid=22222222227000000000&wl0=&wl1=g&wl2=c&wl3=21486607510&wl4=&wl5=pla&wl6=19880599990&veh=sem Item Description The HP Palm Veer 4G P160 GSM Phone lets you connect to your world on the go. This black HP GSM phone has built-in WiFi, which puts Internet connection conveniently at your fingertips. With a smooth 2.6" touch screen, you can navigate through menus and features easily. The HP Palm Veer P160 4g GSM Phone functions as an MP3 player and lets you use MP3 tracks as ringtones. With vibration alerts, this black HP GSM Phone will still keep you up-to-date even when you need to turn off sound. The GSM Phone makes communication easy with SMS and MMS features, e-mail access, instant messaging and predictive text. This HP Palm Veer P160 4g GSM Phone comes with a cSTN 256k color touch screen and an easy-to-use QWERTY keyboard. HP Palm Veer 4G P160 GSM Phone (Unlocked): Sound and Music: MP3/eAAC+/WMA player MP3/WAV ring tones Vibration alerts Mobile Features: Bluetooth v.2.1 with A2DP HSDPA: 14.4Mbps HSUPA: 5.76Mbps microUSB 2.0 port WLAN: 802.11 b/g/n HP webOS 2.1 5 megapixel camera Video capable 800MHz Scorpion processor Accelerometer, proximity MIDP 2.1 Java Browser: HTML, Adobe Flash GPS with A-GPS support AT&T dedicated apps MP4/H.264/H.263 player Document viewer Technical Profile: 84mm x 54.5mm x 15.1mm Talk Time: Up to 5 h Stand-by Time: Up to 300 h Battery: Li-Ion 910mAh Display: cSTN 256k color touch screen Resolution: 320 x 400 QWERTY keyboard Messaging: SMS and MMS Email Instant messaging Predictive text
  2. If you are on AT&T, T-Mobile, or other GSM carrier, you can still get that tiny little HP Veer over at Target for $114.99! http://www.target.com/p/hp-veer-4g-p160-unlocked-cell-phone-for-gsm-compatible-white-black/-/A-14243236?ref=tgt_adv_XSG10001&AFID=Google_PLA_df&LNM=%7C14243236&CPNG=Electronics&kpid=14243236&LID=PA&ci_src=17588969&ci_sku=14243236&gclid=CKzOq5m9jLgCFYuf4AodTWAAOw
  3. I called HP small business shopping to check the order of my Touchpad and cancelled pre 2 phone, they told me that they have 15 or 16 of teh HP veers in stock, you have to call their toll free number.
  4. Do you own an HP Veer? If so, how do you like it? Do you have it on AT&T or other GSM carrier...
