Showing results for tags 'internet speed'.
Found 3 results
  1. Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
  2. Hi everyone. I have a LG 49U67V TV. I updated my internet connection to fiber 100Mbps. My new router uses both 2.4 & 5.0GHz frequencies. With my mobile phone I check my Internet speed with fast.com and it is 100Mbps. My TV connected also via WiFi in the same network can't reach with fast.com more than 12Mbps. What is the problem? Does my TV not support higher speeds? If I change the router settings to transmit only in the 2.4GHz frequency, would something change? Would I loose speed in other devices such us my laptop and phones? No can't connect via cable to the router. And I'm afraid to pay 50€ or more for a power connection I tried something else. I connected my tplink WiFi range extender and then via ethernet cable my TV to this range extender. The problem here is that also the range extender can't reach more than 15 Mbps of speed. I tried to conect my phone to the extender and the result was the same the extender did not achieve more than 15Mbps in fast.com. So the extender had also issues achieving the speed of the ne router
  3. Dear Team, I have LG 49UB850T Smart UHD TV. Recently, I updated the WebOS, from that point, I observed my TV is very very very slow while browsing the Youtube / Netflix / Amazon Prime / SBS OnDemand any live streaming. Here are few details: Model: 49UB850T-TA Seriel Number: 404KCZPR3501 Software Version: 05.05.75 WebOS Version: 1.4.0-2334(afro-ashley) Can I get any fix to this OS version or suggest me what I have to do to fix this issue. Thanks, Kotes
