Showing results for tags 'lg sound synch'.
Found 1 result
  1. Question: Why does LG's website say I should check this forum to see if 3rd Party Bluetooth Headsets with work completely and correctly with LG sound sync and WebOS, when LG has not or will not publish a list of which 3rd Party Bluetooth Headsets are tested as compatible with specific LG TV models? We recently purchased an LG 55UM7300PUA (2019) TV and have a question about which 3rd Party Bluetooth Headsets that are compatible with LG sound sync and WebOS... My wife wants to listen to our 55UM7300PUA TV through a set of Bluetooth Headphones while the TV Internal Speakers are turned off... It seems that LG's USA website needs to be updated because LG's search results about our 55UM7300PUA model seem incomplete. The LG Tech Support website does not list the 55UM7300PUA as a TV nor Smart TV product and no 55UM7300PUA or 55UM73 manual is listed in search results. I finally found the Owners Manual for our 55UM7300PUA through a Google search, but this PDF Owners Manual I downloaded does not say if our 55UM7300PUA supports LG sound sync or which manufacturer/models of Bluetooth Headsets . I am disappointed by a lack of technical support from LG in past forum discussions regarding which 3rd Party Bluetooth Headsets with work completely and correctly with LG sound sync and WebOS. LG Technical Support is forcing customers like me to buy Bluetooth Headsets at our expense, they ask us to do their testing with a lack of specific 55UM7300PUA documentation, and they direct us to "refer to headset model names in user guide" that are not simply listed. Does our 55UM7300PUA support the use of Bluetooth Headphones and is "LG sound sync" required for use with Bluetooth Headphones? Why should we have to test 3rd party Headsets at our expense when LG Tech Support should specifiy which OEM and 3rd party Headsets work with which LG TV models?
