Showing results for tags 'lg tv'.
We own mahamdg.com, a retail store in Iran, MahamDG.com. were one of the primary LG tv distributors in Iran. We also love to sell LG Phones to our customers cause they eventually asked us for LG phone prices. we just have a suggestion based on a poll on www.mahamdg.com , our customers want their L...
If you are looking for an LG TV repair manual to service your TV, you can check out Emanualonline - TV | LG Service Repair Workshop Manuals
Why don't I see the Spotify app on LG smart TV
jaculson posted a question in LG webOS Smart TV Questions
I have a LG TV model: 47LB652V-ZA, webOS version 1.4.0-2523 (afro-ashley). Why isn't Spotify supported for this TV if its from 2014 and it says that devices from 2013 and onwards will be supported -
Hi guys, I have received my LG TV with webOS 3.0 today. I am looking to install a few Apps available on Google Play, however, it seems Google Play is not installed on the webOS software pre-installed. I can only find Google Play Movies and TV, which does not allow me to install 3rd party App...
- 10 replies
- 3
- google play
- lg tv
(and 1 more)
Tagged with:
lg tv Is there LG Channel plus app for India?
Prateek Shrivastava posted a question in LG webOS Smart TV App Questions
Is there LG Channel plus app for India? i can see on internet that there are countries which are using this app.-
- 1
YouTube app isn't working properly on LG 32LJ550B
jorge Ramos posted a question in LG webOS Smart TV App Questions
I'm having a little problem since a few days ago, when I try to use the YouTube app it shows the start screen as always but then it don't show the videos and just grey words appear at the side as if it was the tittles and all the text in the app, I tried starting the app from my phone but it just pl... -
It's been noted on various forums that some LG TV owners can change the country code through the ez adjust service menu. For example: http://forums.webosnation.com/lg-webos-tv/328085-hulu-plus-netflix-overseas-lg-webos-tv.html It appears the instructions covered in the link above are for webos 2....
- 5 replies
- change country code
- lg tv
(and 2 more)
Tagged with:
Hi all. This TV model only has 1 USB port so I was wondering if I could use an USB hub so I can connect multiple devices at the same time to the TV..if so, does it require separate power supply? has anyone tried it? Thanks.
- LG TV
- USB hub extension
(and 1 more)
Tagged with:
