Showing results for tags 'lnb frequebcy setting'.
Found 1 result
  1. Hi I am an AV expert but new to LG smart TV, Recently i purchased a LG 43UH651V smart TV with WebOs3 , i looked in to the specs and it was amazing The TV also performing very well. I have a technical question that any Web OS expert here may can answer my question I tuned my satellite channels (DVBS2) on this TV ( Intelsat 17C 66E) Sadly, this satellite is not listed in the preset satellite lists. I am using an universal LNB to cover both polarities which has a LNB frequency of 5750-5150 But unfortunately the satellite frequency setting of my TV doesn't have this frequency range. i tried to setup it manually, but its not supporting the universal frequencies. I can use 5150 frequency, but its covering only one polarity. and limited TP range frequency also I am attaching 2 images here (one from my existing satellite receiver which is worked fine form me and the other one from LG TV settings So if any one can help in this regard will be much appreciated Many thanks in advance Jasim from Dubai - UAE
