Showing results for tags 'memory restart'.
Found 1 result
  1. Why does YouTube keep 'restarting now to free up memory' and how do I fix this very annoying bug in the WebOS or TV? Thanks everyone for your suggestions, answers. Tend to agree with Petevick as I usually don't have any other 'apps' running in the background to take up the very limited memory. Have contacted LG support via clunky email page and had one reply so far which also said to check for open apps or - wait for this - if it only happens with YouTube 'app' then it is their problem and I should contact YouTube for a fix! Not very helpful, ignores the many consumers with similar issue and gives no indication of a future firmware fix. Looks like LG are another 'couldn't care less' TV manufacturer selling overpriced TV's on the back of 'Smart' features that don't work properly and are unlikely to be kept up to date. Will remember this next time I need a new set.
