Showing results for tags 'remote control'.
Which magic remote is best for 55UT73006LA ?
sunnythekid posted a question in LG webOS Smart TV App Questions
Hi, I have recently purchased the 55UT73006LA series TV and wanted to know if any magic remote will work with this TV? If yes, please let me know which one(s), as I don’t really have knowledge on what works with what. Thanks! -
Hi all, I am trying to find a solution to the native but complex "magic" remote control from LG. For elder or young people, this magic remote control with the OLED C3 TV is too complex or too busy (using a lot of unused keys. The new model for remote control is now either the Apple TV RC, the Android TV RC or the Google TV remote control. All these RC are small, easy to use with only 10 to 15 keys instead of the 40 to 50 keys. I saw that. in the past LG introduced smaller remote control (see below the first image LG AN-MR500) but I am not sure it is supported with the LG OLED C3. I also saw that the latest projector CineBeam Q comes with a small new RC (see bellow). This new white RC has only the necessary keys (max 10) and seems to be fine ! Also, the new C4 is coming seoon and I suppose it will include a new Remote Control but we don't know yet what it is ... Do you have an idea to solve my issue ?
Help me out people! I want to know what is the compactible magic remote for LG UR7500? I looked everywhere, i cant seem to find an answer.
- 1 reply
- magic remote
- remote control
(and 3 more)
Tagged with:
Hi folks, Is there some way to permanently disable the gyroscope in the magic remote? I can set tracking speed to high, medium or low, but "off" is missing :-(. With gyroscope enabled the scroll wheel is extremely difficult to use. As soon as I use the scroll wheel the air mouse is activated again. I have the impression that scroll wheel and air mouse do not agree how to move the pointer. Sorry to say, but thats really annoying. WebOS is version 04.40.15. Every helpful hint is highly appreciated.
- remote control
- magic remote
(and 1 more)
Tagged with:
How do I make my LG TV remote controller quit controlling my Vizio soundbar. Sent from my iPad using Tapatalk
Would it be possible to support natural scrolling for the remote (optionally)? It is pretty confusing that the shown page scrolls down if you push up your thumb on the scroll wheel. Its not what you expect.
My smart TV remote control developed a problem where it would jump up and down the menu. If you have this problem the way to fix it is to open up your remote control (pops open by slipping in to the bottom corner with blade or similar flat item and prize open) then taking the circuit board remove scroll wheel then spray WD40 or similar allow to soak in then wipe off surplus and gently tap out,replace scroll wheel and work it well by rolling it then wipe again and put back together....job done!
