Showing results for tags 'resolution issue'.
Found 2 results
  1. I recently bought a UHD tv 65UP75003. I'm not sure, but I think there was a problem after the software upgrade. The TV is connected via an HDMI cable to a DTV receiver that sends 1080i resolution and the problem is in the horizontal line that travels from top to bottom. The line is not visible at progressive resolution. What I did: Reset the TV, receiver, bought a new high speed HDMI cable ... Please help and what to try next? https://photos.app.goo.gl/tyjifdpGLFAXmKd88
  2. Hello, I have a weird issue with movies encoded in 3840x2076 resolution on my LG EG920V (WbOS2.0). Somehow the TV doesn't properly handle this resolution. As you can see in the attached picture half the screen is noisy with a green horizontal bar at the bottom. I tried to play the same file (.mkv) from PLEX (Xplay/Plex), EMBY(Emby Theatre/Screenplay), as well as directly from USB HDD - the same result. The conclusion, TV's internal player can't handle 2076 vertical resolution. As an workaround I added horizontal black bars on top/bottom (42px each) with ffmpeg, but it's a very very slow process - on my AMD Ryzen 7 3700U (8 cores) it runs ~1fps. Anyway the result 3840x2160 runs without issue. Is there any fix for this issue? Kind regards,
