Showing results for tags 'smart card'.
Found 1 result
  1. Hi there, I've got cable-TV decoded throw an inserted smartcard (CI+ Module). The card comes with a parental control pin activated, and I'm forced to insert it way too many times. In the card's documentation says that the TVs should have a many to remove the lock, however I can not find it in mine. This is NOT the webOS's built-in security PIN, that one is completely deactivated, and the input even looks different. Does anyone have any clue? Model : 55LB630V webOS: 04.32.20 Thanks.
