Showing results for tags 'time machine'.
I have a one year-old model 43UK6500AUA, with standard remote only (no Magic Remote). I can find no mention anywhere of Time Machine. Does this model not include Time Machine II functionality? Must one have a Magic Remote to reveal this feature? I am also baffled by numerous references in the forum to using HDMI , which should not be necessary if using the TV's built-in tuner, as I intend to do. There is also mention of using USB3 for the external HDD. My TV has only two USB ports : USB1 and USB2 — or does this refer to USB 3.0 version (as opposed to USB 2.0)?
- 3 replies
- magic remote
- 43uk6500aua
(and 1 more)
Tagged with:
Hi I have just got a new OLED B7 TV and would like to know if I can use my old USB HD that I was using with my old LED LG TV that was using the LG time machine 2. When I plug the USB HD into the new B7 TV it says I need to format it. I see the new TV's need a NTFS drive and on the old LED TV it was using a linux system. Is all lost are any way to view the old data on the new OLED TV ? Thanks Paul
- 1 reply
- time machine
- usb
(and 1 more)
Tagged with:
Will Web OS allow recording from HDMI input ?
g.satish08 posted a question in LG webOS Smart TV Questions
Will Web OS allow recording from HDMI input ? -
What was the possible reason to implement the condition so there has to be at least 40 GB of free HD space to be able just to start the recording?? I made 2 partitions on my 160 GB hard disk - the first one of 40 GB assigned to Time Shift/Recording and the second one to store the movies - and now I cannot anymore start the immediate recording because it says 'There must be minimum 40 GB of free space to start the recording'!! My question #01 is: Why in the h... would I've been forced to have the free space to store hours and hours of the recorded video if I want to record just a short TV show???? There, hovewer, is a (silly) workaround: 1. Just watch the show you want to record 2. After the show ends, rewind it back a few minutes before it began (Live Playback has obviously to be turned on) 3. Press RECORD and immediately after press STOP (and choose to save the content - that will save everything from the point where you rewound to present time) 4. Open Time Shift and start the newly recorded video 5. FF to the exact start of the show and press PAUSE 6. Use the mouse to press the arrow to open some additional commands and choose Save Selection (the in-point will be marked with A) 7. FF the video to the exact end of the show and press PAUSE 8. Press Save Selection one more time at the out-point to cut-out everything but the selected part of the video This workaround allows you to 'record' even if you have less than 40 GB of free HD space, but that way the max. length of saved video is 1 h 30 min (because Live Playback saves only last one and a half hour). My question #02 is: How it is supposed to fill the last 40 GB of the hard disk space if you can't even start the recording when you have 'only' 39.9 GB of free space???? The 1 h 30 min of Live recording can't 'eat' those 40 GB even if we are watching the maximum rate 1080i TV show so those 40 GB are not intended to be used by Live recorder. The only way to fill the last 40 GB of HD space seems to be in the case of recording for hours and hours!?
