Showing results for tags 'turn on'.
Found 2 results
  1. My new LG TV (65UM6900PUA) running WebOS 04.71.25 works great with HomeKit, with the exception that it is not reachable while it is turned off. If I try to turn it on in the home app, it says "No Response." I have changed the 'Turn on via Wi-Fi' setting to on, and it will turn on from the 'LG TV Plus' app, but not from the iOS home app. Is there a specific setting or something I need to change?
  2. A few weeks ago I buy a new LG tv. After a week of use it start to turn on relay slow. I turn it on end the screen is black. I need to turn it of and on and of a few times for it to work properly. How can the problem be solved?
