Showing results for tags 'update error'.
Found 2 results
  1. Hello everyone, I have this issue with my 49" LG TV (Model number: 49UN71) that has just been stuck on WebOS 03.10.60 with no way to update it to the latest version of WebOS. I don't know if this is normal or not, but I think that it's a bit particular that my 2020 TV is running a firmware update from 2017 with no updates on the horizon. Please leave a comment if you know what I might do in this situation! Thanks
  2. Hi, I'm new here. I have a 43LF6300-TA WebOS TV. I have upgraded it to WebOS4.0 just recently because I was trying (in vain) to access WIFI and LAN connection hoping maybe the updated firmware might fix the issue somehow. Previously, I cannot update any smart tv app and all. After the firmware update, the screen says WIFI or LAN is connected but still I cannot update nor access any smart app or internet etc. If I click on an app, it says update needed. If I click on update, NETWORK ERROR 3 appears. I have a Samsung UHD TV, and setting it up to WIFI or LAN was a breeze. Need your help on this issue. thank you in advance.
