Showing results for tags 'web browser'.
Found 7 results
  1. When are you guys going to update the browser to 2023 standards for all content....because there are certain streaming sites I use that LG does NOT have an app for. My tv is a 55" 4K LG webOS UK6200 Current software version is 05.50.10.
  2. I cannot update the web browser. The webOS seems to be updated or doesn't need any other update. Any other app gets successfully updated. Tried to unplug the TV and plug it back again but didn't work. Any tips would be appreciated. :)
  3. The following URL is not correctly handled by the LG webOS web browser: https://www.reuters.com/video/ BUG: Just before the end of each video segment, the video pause and needs to be restarted with a manual play input on the remote. Please advise.
  4. I'm trying to open up a web browser on our new 43UM750 OPLA set. On this webos site the instructions are clear "To open the web browser click on the home button on the remote, and select the button on the screen that appears as 3 diagonal dashes" they start. But when I push my home button, there is no sign of those three dashes. What am I doing wrong? Or are those instructions out of date? Or is there something not mentioned there that I need to do to make those three dashes appear?
  5. I have been having problems watching movies on LG web browser on my smart Tv. But I have downloaded a TV cast app on my iPhone and on my Tv off LG App Store. Now using these apps I can stream movies onto smart Tv using Tv cast app and it dose not crash or say App will now will restart to free up memory.
  6. Howdy, Bought myself an LG 60UH770T-HT (in Australia) and love it. It's the first 'smart' TV I've seen where the OS doesn't make me want to make it un-smart, Android on TVs is just awful in my experience. Is running LG Software version 3.17.20 at present and Web OS 3.1.2-1217 (dreadlocks-denali). I'm really keen to find out if I can install 3rd party apps such as a replacement web browser for the very limited one that came installed with the TV etc.... Things I'd like to do / find out if I can do: Upgrade the inbuilt hard drive to a larger SSD. Install a better web browser (one that's updated, security patched, allows downloads etc...). See if I can enable any more advanced settings. Customise the interface layout. Train the smart remote to the IR codes for my QUAD Vena integrated amp.I contacted LG via twitter and they weren't at all helpful, essentially blew me off to talk over the phone then changed that to logging something with the Australian only website, they didn't even respond when I said that the QUAD was a UK brand and widely used all over the world, they made it pretty clear they didn't care. Twitter convo started here: https://twitter.com/s_mcleod/status/756353546245672961 Moved to a DM convo LG support blowing me off.pdf Contribute back any learning / information I find out to help others. Mirror my iPhone directly to the TV, I'm hoping there's an Airplay receiver app out there somewhere. Add Getflix, or a quick way to switch between DNS servers to the UI. And probably a lot more.
