Showing results for tags 'webos 3.5'.
LG UHD TV digital sound out popping noise problem
Krash01 posted a question in LG webOS Smart TV Questions
Dear Readers,I've a strange issue that I've been struggling for a week. I bought an LG43UJ634V UHD TV and an LG LHB645N Home Theater in a Box system.I use HDMI ARC to connect the audio from the TV to receiver. LG has an option to chose between PCM or Auto at the Digital output settings.If I use the PCM option everything sounds great, but I don't have 5.1, only 2.1.And here comes the problem. When I choose Auto, 5.1 is on, sounds great but I have occasional popping noise (like when play something on an old LP player) it happens random, but for example during a film, it is very annoying. It happens with YouTube, Netflix, DLNA streaming, external devices, so the content doesn't matter. I think I've tried everything. I tested it with different HDMI cables, optical cable, but still have the problem. I tested it with a sound bar as well, the problem is the same.When I play content from the receiver, there is no problem, the sound is wonderful, no popping. Also, the TVs speakers are okay.I don't think it is a hardware issue, because the TV's sound is OK, the home theater's sound is OK, the problem only happens when I want to use the digital output of the TV (either HDMI ARC or Optical) with auto setting.I called LG as well, the rep. said the she will pass this info to the technical team.Do you have any idea, that it can be solved, or I need to wait for a software update? -
HI All! Just got myself OLED65E7P and for the love of God I can't find Pandora app Could someone point me in the right direction, please. Thanks!
55LJ550M WebOS 3.5 - Poor AAC Performance over ARC
Hunter_S posted a question in LG webOS Smart TV Questions
I have a 55LJ550M (WebOS 3.5) TV, connected to an A/V Receiver via ARC. Per the online documentation, when the TV encounters AAC audio, it will transcode that audio to Dolby Digital for transmission over ARC. See: http://www.lg.com/ca_en/support/product-help/CT20098005-1437136302910-others However, the sound quality is very poor when this occurs. The sound is full of compression artifacts, and with some older A/V Receivers, this causes the sound to periodically cut-out. Some of the WebOS applications affected by this issue are YouTube (which mostly uses AAC audio), any Netflix stereo programming, and using the Music\Photo\Video app to play music or videos with AAC audio. To me, it makes the entire YouTube application unusable. Honestly, I'm surprised that WebOS doesn't just output PCM audio over ARC whenever it encounters AAC. This would make more sense, and it would require less processing power and sound much better. (I know that I can set the TV to output everything to PCM over ARC, but I do not want to lose DD 5.1 and DTS sound from other programming which works perfectly). Is this behavior a known WebOS 3.5 issue? I know that my unit is a one of the cheaper LG sets--it is possible that this particular set is just too under-powered to function as designed? -
Hi, new user today with OLED65C7P. Streaming NETFLIX, Amazon, Sling TV and Tablo works great. Question... when I turn TV on it comes on Live TV. Can I change that? No antenna or cable attached. Steve
Find out what's new in the webOS 3.5. Now, all you have to do is relax as webOS 3.5 makes the TV experience simpler than before. Set to be found across ‘LG’s entire lineup of premium TVs’, the latest webOS system - named webOS 3.5 - will deliver a range of improvements taking in everything from enhanced remote control features to getting you closer (literally) to the action with improved zoom functionality. Starting with the improvements made to LG’s Magic Remote handset, it will be possible to instantly access your favorite streaming service - such as Netflix or Amazon - by pressing a single assignable button on the remote. LG has nipped in ahead of the official launch of the CES in Las Vegas to reveal details of the latest improvements it’s introducing to its much-lauded webOS smart TV interface. Set to be found across ‘LG’s entire lineup of premium TVs’, the latest webOS system - named webOS 3.5 - will deliver a range of improvements taking in everything from enhanced remote control features to getting you closer (literally) to the action with improved zoom functionality. Starting with the improvements made to LG’s Magic Remote handset, it will be possible to instantly access your favorite streaming service - such as Netflix or Amazon - by pressing a single assignable button on the remote. All premium 2017 LCD TVs, including the SJ95 series pictured here, will support webOS 3.5. (Pic: LG) The new ‘Magic Link’ button will also streamline the process of accessing background information on what you’re watching, such as bios of the actors. As for the improved Magic Zoom feature, this will let you not only zoom in on parts of the image with enhanced control and quality, but also let you record the enlarged image - a potentially handy way of solving household disputes over, say, just how bad a supposedly dangerous football tackle really was. WebOS 3.5 also jumps aboard the VR bandwagon. If you connect a webOS 3.5 TV to a VR-capable computer or mobile device via USB cable, you can not only watch 360-degree VR content on your TV but also use the Magic Remote to move the scene in any direction and zoom in and out of the image using the handset’s handy scroll wheel. Content source
