Showing results for tags 'webos install failed'.
Found 1 result
  1. Hi Webos Developers, Just build the First application in Windows 10 with following steps. 1. ares-generate -t moonstone-2014 first-app 2. Edited appinfo.json (with id as com.test.app.firstapp) 3. ares-package first-app 4. Run the webOS TV Emulator. 5. When I try to install, following command is not responding. ares-install com.test.app.firstapp_0.0.1_all.ipk Tried to add the application from webOS TV Emulator v3.0.0 but no luck. Please advise. Thanks, M
