PSA: TouchPad cases dirt cheap!
So you're a TouchPad owner. Maybe you purchased it full price or maybe you waited until the now
of the TouchPad after good ol' Leo Apotheker . You might even be one of the hardcore webOS users that paid top dollar for a beautiful with a whopping 64GB of storage! Regardless of how you got your hands on one or how much coin you dropped on it you love your TouchPad all the same. Because you love your TouchPad you want to protect it with the best case possible. However sometimes a good case can be a bit expensive so we all tend to look for the best deal possible.
Well if you're looking for a deal look no further than HP's very own Home and Home Office Store. Here is a quick list of all the great deals they have right now:
  • HP TouchPad Slipcase: $1.99
  • HP TouchPad Power Charger: $4.99
  • HP TouchPad Case: $4.99
  • Timbuk2 Envelope Case: $14.99
  • Timbuk2 Plush Sleeve: $14.99
The best part is all of this can be had with free shipping. So act quick folks because we are sure at these prices supplies will not last very long!
a2t.imgcpXxqVR7X2w
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By ajmboy
    • By Alex
    • By pivotCE
      First, no this is not my auction nor do I or pivotCE know the seller in any way! This crazy deal is just too good NOT to tell you about.
      Every once in a while a Palm Foleo pops up on eBay with a price tag to match its rareness…usually around $1000 USD (or $2300 like
      link hidden, please login to view)! But these? A paltry $179 and $11.65 in shipping (only to the USA though) and that’s the Buy It Now price. You can make an offer and possibly get one or both of them for less. For the PalmOS nostalgic, it doesn’t get any better than the Foleo. The auction has 27 days left at the time of this writing so they’re up there to sell. See the video below for an idea of what the Foleo could have done since it was .
      #PalmOSforever
      Related posts:
