By
Manish Ritwik
Hello:
Hotstar App not available on LGWEBOS is 05.30.60 Model: OLED65C6P
LGStore: USA
Tweeting @hotstartweets they replied to contact LG Support see below:
Our app has been available on LG WebOS since 22nd Mar in India. If you have WebOS 3.5 or above and a supported TV, you should be able to find it in the store. For device specific compatibility details, please contact LG support.
Can you please advise am I unlucky the one who cannot be helped by LG Support or by Hotetar App Team OR there is a ray of hope?
Please advise ASAP!
Latest comment by @hotstartweets
We do support the OS version you have mentioned. For device compatibility you will have to contact LG support, as there is very less that we can do in this case.
Manish, we developed the app and it is available for all our LG TVs with WebOS 3.5 and above, so if there is a TV which is not showcasing the app, it is a compatibility issue from the device manufacturer, and how much we try to help you with this it wont help, as it is a device related issue.
