Hi,have LG tv approx 2 years old now when we pause a programme and restart no sound just buzzing sound.
We then have to turn off tv and restart and sound then returns when we press play,not sure if this tv fault or sky?
Any suggestions welcomed.
Thanks... Peter.
    • By JamieG
    • By Di59
      I have 2 LG smart Tv's and I am unable to pause live TV with my 40Gb USB which I have formatted to NTFS.
      TV models
      43UJ634V
      And
      32LM6300PLA
      Please can you give me easy to follow instructions so that I can set up both Tv's to be able to pause live Tv and to be able to record programmes.
    • By 5zwed
      I've recently bought a 65QNED913PA TV (currently with latest official software) and I connected my Bluetooth headset to it - Jabra Elite 85t. Whenever I try to use pause button on my headset (while watching YouTube, Netflix, Disney,...) sound gets muted, but video does not pause. When I push the button again sound comes back and nothing else happens. Should my TV support pausing video from my headset or this does not work by default?
      Regards
      Maciej
      SUPPORT MENU
    • By GiotisCy
      I have recently purchased an LG C2 Oled TV which I connected with my Samsung HW-Q800B 5.1 soundbar via eArc HDMI. When I select "Passthrough" as a Digital Sound Output on LG TV sound advanced settings, there is an obvious sound response delay around 3 seconds when I pause and unpause the movie on Netflix or Prime video streaming apps on LG TV. For example, when I start the movie, the video starts and sound starts 2-3 secs later. When I pause the movie, the sound continues for 2-3 secs after the video has been stopped. There is no any lip sync issue, just this response delay of the sound from the soundbar. This happens only on LG TV Apps. If I connect to an external HDMI device such as AMAZON Fire Stick 4K, there is no such sound delay issue neither on Netflix neither on Prime Video.
      Thus, the problem seems to be on LG TV apps.
      If I change the Digital Sound Output to "Auto" instead of "Passthrough" the issue is gone but sound quality is not as good as with Passthrough selected. So I do not want this to be my option.
      I would appreciate if someone could come with a solution on this.
    • By Sam Athans
      I have just upgraded from an LG 06LF6300 TV to an LG OLED65C1PTB. On my old TV I could pause live TV for up to 90 minutes and replay at a later stage.
      Can anyone advise if this feature is available on the LG OLED65C1PTB.
      Sam
