Spotify not appearing
The Spotify app may not be available on some LG TVs due to compatibility issues. The Spotify app is only compatible with LG smart TV models from 2016 or later, all of which run LGs webOS. If you have an older model, such as the LG TV LF630V, which is from 2014, the Spotify app may not be supported.
In such cases, it's recommended to consider alternative methods to play Spotify on your TV, such as using
, Google Chromecast or Apple AirPlay. Additionally, ensuring that your TV's firmware is updated and that it is connected to a compatible network may help resolve the issue. If the app is not available, it's advisable to explore other devices for streaming Spotify content.
it may be due to the LG Tv model doesn't support Spotify app.
If so, you could better try another way.
I prefer to play Spotify music via a USB drive.
To do that, it is easy. I just use AudFree Spotify Music Converter to save Spotify music to USB drive for playing on LG TV.
    • By anna groove
    • By Annie Yazbeck
      I can't find the Spotify app on the LG Content Store. When I search it, there is no result. Anyone can help me to get Spotify on LG Smart TV? I tried to use DRmare Software to download Spotify songs to USB flash drive and play them on my LG Smart TV offline for free. But I prefer to use it via the Spotify app directly.
    • By Bella Lee
    • By leodavid
      I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
      The buttons work fine but for some reason, I can't get the cursor to appear on screen.
      Appreciate the help. Thanks
    • By Pagy
      Hello, ive got LG 55UF7787-ZD and i dont have available Spotify on it. I tried everything, even upgrade firmware by hand, but nothing helped to get it available for me. If somebody has some solution how to install an app to the TV, please let me know. I am not interested of some tricky crazy converting of albums and downloading it in advance. I am really looking for solution to have installed application in my TV, thank you.
