Is there an app for WebOS which determines and displays the speed of the Internet connection?
Go to solution
Solved by Smartboy,
By Khelben Arunsun
By Prakash Sahoo
Hi Team,
Prakash Sahoo
By tarakdave
By AtWitsEnd696
Bob17821
I have problems with one of my WebOS TVs which looks like a speed problem, but when I do a speed check on my iPhone from just a few feet away the connection speed looks fine. Thanks, Bob
