How to customize WebOS home screen
Hello guys, this is my first question in this blog. I just bought recently a LG OLED65C3 and I am very happy. However, I would like to simplify the homescreen as much as possible. I already removed the ads in the top part of the screen.  Then I would like also to remove the colored tiles (dashboard, music, advice ...), not sure it is possible. I would like to keep the app bar in the middle, of course. Finally, I want to remove the bottom of the screen like the TV Guide, user's guide ... Do you think this is someting possible ? Aslo in the web app bar in the middle, there are some applications like Sport Alerts or Dashoard I cannot remove from the bar ... It would be nice to be able to simplify all the home screen for my elder and kids.
After some tests on WebOS 23 on the home screen, you can just remove the ads, remove all the tiles (or cards) except the "Mofify" card that will stay in the middle of the screen. Concerning the "Apps" bar, you cannot remove some specific ones like the browser, the dashboard, ...  And finaly the bottom items cannot be removed at all (you can just remove the recommendations from the general parameter menu). To summarize, you cannot customize the home screen ... It is really a pity.
    • By DWINKS49
    • By Batman
