    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By Chris Schults
      Everytime when we are watching a program we like very much.
      Suddenly appears on the left side of the screen some Recommended content.
      It takes too great part of the screen, and besides that the content it shows is not what we like too.
      I closed my account on the telly, but still it shows up every day.
      I can not find a solution for it.
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
