WP CentralWhile you will not typically hear complaints about the Wi-Fi on most webOS devices, the Pre3 seemed to take a step backward in the reliability of its wireless radio. In addition to a seemingly decreased W-Fi range, it also tends to not show all the available networks that are in range, even if they are
. This can be an extremely annoying bug that will cause your device to fail to connect to a known network, but it has an equally annoying (although relatively simple) fix. All you need to do is turn Wi-Fi off and then back on again, and all the wireless networks within range will show up again.
If you are a homebrewer, you can also install the "Cycle Wi-Fi in Device Menu" patch in Preware by GuyFromNam that will, not surprisingly, add a "Cycle Wi-Fi" option to the device menu to toggle your Wi-Fi off and then back on. This also appears to work alongside some of the Device Menu expansion patches such as Jason Robitaille's "Device Menu Megamix" patch.
a2t.imggJvF7DnA6CQ
    • By akhil7j
    • By Tunari
    • By Ramesh Chand Vishwakarma
      Regards,
      MD/CEO
      Noida, UP
      +91 9910246766
      First in the 5G Private Network Industry to Receive Domestic Network
      Equipment Certification from Korea Association of Network Industries
      SEOUL, Sep. 26, 2024 — LG Electronics (LG) is stepping up its presence in the 5G private network market, a key infrastructure for future industries. The company has recently achieved a significant milestone by becoming the first in 5G private network industry to receive the “Domestic Network Equipment Certification” from the Korea Association of Network Industries for its self-developed 5G private network solution.
      The “Domestic Network Equipment Certification” is awarded to products that are developed and manufactured in South Korea, a key credential for supplying to public institutions. This certification marks LG’s official recognition for internalizing core 5G private network technologies.
      A 5G private network is a customized network deployed in specific areas like factories and buildings, offering high-speed data transmission and exceptional stability. It serves as a vital foundation for innovations such as digital and AI transformation (DX/AX) and smart factory operations.
      LG’s certified 5G private network solution leverages advanced software to handle network functions typically managed by traditional 5G equipment like Radio Access Network (RAN) and 5G Core. This software-based approach allows for faster data processing and improved stability, with the added benefit of enabling upgrades without hardware replacement, significantly lowering operational costs.
      Harnessing its strong software capabilities, LG’s solution delivers a customized 5G private network tailored to meet diverse client needs and installation environments. For instance, it can create secure, isolated networks for clients with high-security requirements or integrate external cloud services for companies that require frequent collaboration with external partners.
      In addition to network setup, LG’s solution offers a device control platform for seamless management of connected devices. This includes LG’s own products, such as robots and digital signage, as well as clients’ existing equipment like CCTV and smart safety devices, all integrated via the 5G private network.
      With the momentum from this domestic certification, LG plans to actively pursue both enterprise-focused and public 5G private network initiatives, targeting sectors like smart factories and more.
      Recognizing the immense potential of the 5G private network market, LG has committed significant resources to technology development. The company holds around 30,000 telecommunications patents, including many related to 5G, ranking it among the world’s top innovators. Last year, LG formally added “facilities-based telecommunications business” to its portfolio, positioning itself for full-scale commercialization of its 5G solutions.
      LG also brings extensive real-world experience, having tested its 5G private network solution at various reference sites, including its Tennessee factory, a smart factory in Chungbuk, a logistics center in Incheon and a university hospital in Seoul.
      The global 5G private network market is expected to grow rapidly, from approximately USD 2 billion in 2023 to around USD 11.8 billion by 2028, with a projected annual growth rate exceeding 40 percent, according to market research firm MarketsandMarkets.
      “We will continue to provide customized 5G private network solutions for clients who need fast, stable networks, leveraging our outstanding 5G technology and operational expertise, accumulated in various sectors such as factories, logistics centers and hospitals,” said Lee Jun-sung, vice president and head of LG’s Private Network Business Development Department.
    • By forum1
      My LG 49UB850V LED TV  browser is too old. The most of the pages not work any more. How to easy update just one simple browser app? For example, often browser show error during open new page. It show certificate expire problem and page not load at all.
      This mean LG sell product without update at least browser certificate and now we are stuck and can not even load one page from WWW.
      Shame on you LG. I will not buy any more from you.  How dificolt is to release new update to update OS certificates? Microsoft Windows did this, android did also for old phones, etc... Really, can not undestend this asian people from Korea.
