By Venkata
Hello Team,
By mean2
By OhmorrowSouthWales
By starwoodtech
I followed the instructions to set the default input on my TV, but every time I cold start it, it simply goes to the screen where there is a list of apps. I try to repeatedly go to the HOME app to try to set it again, even though it already shows HDMI 4 as the start up input, but it simpy goes to the default screen where my apps are listed.
Does anyone know what it would take to set this?
By Flavio_S
- 2,002 views
- 1 reply
- 2,235 views
- 2,408 views
- 2,241 views
Alfaro
I have a problem with my LG 43NANO756PR: if an app is paused (for example a youtube video or music track is put in pause), after about two minutes the TV goes back to the TV antenna input. Very unpleasant if you are on the phone and need a quiet environment. Same thing if I mute the audio: after about 2 minutes the volume resumes as before.
Any way to sort this issue?
