Ballz HD app review
Some games are good time sinks, taking up hours upon hours of time. Others are good for a few minutes here or there when you've got just a few minutes. And a few bright games fall into both camps, good for the quick round or whiling away the hours you should be spending working. We've come across a new game in the App Catalog with the unassuming (and admittedly vague) title of
. When the description said it was good for everything from the original Pre and Pixi to the big-screen TouchPad, well, we couldn't help but take a look.
a2t.imgcI55B1ZS9fo
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
