No Manual Tune option
I have an LG OLED55C PLA tv connected to a community satellite dish. Its set to 28.2E
Recently channel 103 ITV  does not work and I get a message 'no signal' however channel 111 ITV is working but only in SD, and the picture quality is poor with the faces of people very fuzzy around the edges and sometimes out of focus.
I tried retuning but there is only the option to auto retune which results with the same issues.
I tried a different postcode which worked on C103 but then got the 'no signal' message on C104/105. The different postcode gave me C103 HD but obviously the wrong regional programs.
Is there anyway I can get the manual option to appear or can I change the Transponder settings?
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By duckie133
      VERY ANNOYING!!!!!!!!!!
    • By Cash
      Have LG OLED 55B36LB bought in 2023 in UK.
      Trying to change area option from 3122 (EU-UK) to 4816 (AJ-India) using a service remote.
      It does not update or change.
      any help for guidance will appreciated.
    • By whaleandtuna
      Please Help. I have LG qned tv with webOS 23
      1) What I did: with svc remote -> in start -> 0413 and all, area option was changed.
      I was trying many numbers to find the code for KR (which didn't work).
      2) What I wanted : change area option from CA -> KR (widely known area codes do not work)
      Original code: CAD 22411
      3) Problem: Once I put a number between 19461 ~ 19489, Language&Country is set to EU and would not change the country with the other numbers.
      Area option: 19461 ~ 19489 Continent index: 5 ~ 33 Language & Country: EU
      Now I put 22411 to change it back to original region, but the country would not change from EU to CA, the area option is back to 19461.
      If anyone is trying the area option numbers, don't put any number between them.
      If any one knows how to resolve, please help me to escape from EU.. I am so desperate.
      FYI just in case
      hk 17930
      hk 17935
      co 17560
      ph 15670
      cn 17816
      ja 17211
      aj 17083
      tw 17432
      pa 17679
      hn 18618
      ca 18362
      mx 18456
      hn 18584
      br 18789
      cl 18876
      pe 19033
      ar 19123
      ec 19251
      jp 19345
    • By Satya_
      Software version 05.30.10 default web browser just updated and the address bar appear on the top of the screen which bother me a lot while playing a video please add a Full screen option to it
