Netflix buttons keep switching after the latest update
Go to solution Solved by cptl,
Any thoughts?
  • Solution
This has been solved by LG tech support - it was one of the devices plugged to the tv that was causing trouble. After unplugging all HDMI cables and plugging them back again, everything works like a charm.
Thank you very much. Your solution helped to me also, I had same issue one year already, however that time LG neither Netflix support didn´t helped. Only what I have to add, in my case wasn´t problem caused by HDMI, but by USB. Solution was the same - just disconnect USB. Many thanks
    • By OliverRC
    • By Ajothen
    • By atcronin
    • By Batman
