Good afternoon, someone can tell me which RJ45 to USB 2.0 adapter is compatible with an LG C2 WebOS 6 (LED 55" LG OLED55C2PSA 4K Ultra HD)? I can't find it. Thank you very much. Caap
    • By Musica napoli live e anteprime
      Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
    • By md127
      Anyone aware a Gigabit Ethernet adapter model that might work with this TV. I already tried the Cable Matters adapter but it didn't work.
      Adapter:
    • By maxou
      Is it possible to add the driver for external usb 3 gigabit ethernet adapters  in the firmware to support them and get more network bandwith like on the oled TV C9 and CX (see https://www.youtube.com/watch?v=RgJUUNCsHao) to give to the product the ability to play 4K hdr mkv remux of high bit rate blurays without stuttering (like gemini man or billy lynn for example streamed from Plex server with giga network) ? If you play the same file on direct attached usb drive, no stuttering at all and it's ultra fast to load and fast forward for example.
      It already supports external usb2 FastEthernet adapters with ASIX AX88772 chipset and work well on both type A and type C ports, I have tested it, but it is also a 100Mbit/s adapter like the integrated one, so same bandwith, and stuttering is always here.
      The driver that need to be added to the firmware is the one for the usb 3 gigabit ethernet adapters with ASIX AX88179 chipset like on oled C9 and CX, but no luck, at least with firmware 3.0.0.8 it is not supported, eihter with type A  ports or with the type C port (I have tested both, RJ45 leds stay OFF, the same with a power usb 3 hub in between, driver not included in the firmware).
      I have also tesed usb3 gigabit ethernet adapter with realtek RT L8153 chipset, wich is seems to be supported on older oled C7 and C8, but it is also not supported (blinking leds this time but no connection, driver not included in the firmware).
      This is very frustrating for a 1800$ product !
    • By Adrians
      I have a new LG OLEDGX65 TV with a Sonos EARC sound bar but having a problem with connecting a Bernafon hearing aid adapter which requires a optical or RCA output. (
      link hidden, please login to view The problem is the optical & analogue outputs are not available when a Sound bar is connected via the HDMI ARC input.  Its possible to connect sound bar using optical but then you loose the control of the sound bar volume(HDMI CEC). Yes you can use the separate APP but that's not a really a viable solution.
      So does anybody know of an adapter that can be put on the the HDMI aARC connection to extract the Audio for the hearing aid adapter ?
      The ARC sound would also need and be seen by the Sound bar.
