PreCentral: Fix "Not Enough Storage to Download" error (homebrew)
not enough storageHave you ever tried downloading an app from the App Catalog, only to get a "Not Enough Storage to Download" error, despite
on the device?  Although the error message suggests clearing space on your drive by deleting music or photos, this will not help the issue if you already had enough space for the app. As it turns out, there is a bug that sometimes occurs if your /var/luna/data/downloadhistory.db gets too large, causing one of the internal drive partitions to get full. Luckily, a simple fix for this was found in our webOS Nation forums, where just need to delete that file with some simple homebrew magic.
The easiest way to fix this is by using the homebrew app.  To delete that file:
  1. Open Internalz Pro
  2. Navigate to the /var/luna/data folder
  3. Find the downloadhistory.db file. Tap on it and select "Delete" and then confirm the deletion in the pop-up dialog. Alternatively, you can also the file as well and then confirm that deletion
  4. your device
Once rebooted, you should be able to install apps again. If you are still getting the error, make sure that on your device
Thanks to @Pre2Ries on Twitter for identifying our with this tip
a2t.img5zxk-jQBDJA
    • By mycop
      Greetings.
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By Puja aingh
      Dear LG TEAM
        Kindly resolve this issue
      My lG TV MODEL NO IS 32LK628BPTF
