Bluetooth constantly drops out
55UJ651V After a few minutes, the Bluetooth clicks and disconnects. Sometimes it then re-starts the tv into the on mode, with nothing selected. It will not find the bluetooth device again. Unless, I try a different Blutooth device and then it does the same thing all over again. Is there any answer to this - or does the module need replacing. There seems to be a lot of discussion online regarding Bluetooth issues with LG. I have hearing issues and must use headphones! This is impossible!
3 answers to this question
I don't have an answer for you situation. However I have be using my Bose Quiet Comfort 35 headphones now for about 5 years with my LG TV and have not had any problems.
Maybe try some other bluetooth device ie. ear buds or other headphones and see if the same thing happens...
Thanks for your comment/reply. Yes, naturally I verified that it is not my Anker headphones. To be honest, it would be a lot easier if it were. At least I could get some CS. It does exactly the same with my My MI Earbuds. I have turned off every other Blutooth device. All to no avail. I get no replies from LG Spain! I'd even buy a new BT module and replace it myself. But they don't answer that either!
After having this exact issue, I researched Reddit and found the solution. It was simply disconnecting and reconnecting the Arc connection which was confusing the Bluetooth connection.  I then remembered previously showing my brother what the unplugged Optical (Arc) sound cable connection looked like when powered, which is like a red laser, that was connected to my sound bar and that's when i probably confused the bluetooth connection after plugging it back in.
So I then tried unplugging the optical sound cable and plugging it back in, and so far the problem is solved. I haven't tested HDMI Arc connections because I don't use that connection anymore and therefore haven't tested it.
