Samething happened to me a few weeks ago.  Finally concluded that the wifi card was fried by a momenntary power failure.  I wanted try a wired connection to see if the problem went away but it just wasn't practical.  (And I sort of wanted to replace the set with a new OLED model.)  Was there any evidence that there might have been a power failure prior to the wifi breaking?
    • By NickL
      Br,
      Nick
    • By agus
    • By David Daul
    • By Horniak
    • By CJ Catalano
