WP Central
Road trips are always fun and a great way for families together. But getting to your destination isn’t always a pleasure. You always have a tiny backseat driver trying to distract you while you manuver through minivans, RV's and motorbikes. Wish the shoe was on the other foot?  We may have the solution for you. So while you are busy trying to not entice road rage or an accident, give your kids a game so they can see what it’s like to control a car in traffic:
a2t.imgATUDllIW2mY
    • By Regis Wheeler
    • By JasonB
    • By matesz
    • By matesz
    • By Smartboy
      Hi all, I am trying to find a solution to the native but complex "magic" remote control from LG. For elder or young people, this magic remote control with the OLED C3 TV is too complex or too busy (using a lot of unused keys. The new model for remote control is now either the Apple TV RC, the Android TV RC or the Google TV remote control. All these RC are small, easy to use with only 10 to 15 keys instead of the 40 to 50 keys. I saw that. in the past LG introduced smaller remote control (see below the first image LG AN-MR500) but I am not sure it is supported with the LG OLED C3. I also saw that the latest projector CineBeam Q comes with a small new RC (see bellow). This new white RC has only the necessary keys (max 10) and seems to be fine ! Also, the new C4 is coming seoon and I suppose it will include a new Remote Control but we don't know yet what it is ... Do you have an idea to solve my issue ?
