cannot connect Mac "AirPlay" to LG Smart TV?
hi all,
for a couple of years now, I've enjoyed AirPlay between my mid-2012 MacBook Pro and my LG Smart TV. But last week, I had to do a Migriation Asst./Time Machine re-install of the system drive on my MacBook Pro/Mojave. Result is that I can no longer get a connection with my LG TV. Two things:
  1. When attempting to AirPlay connect, I now get a Mac window asking for a PIN code. Then , the LG goes black and gives me a 4-digit AirPlay code, I enter it in to the Mac, but it reports, "could not connect to LG TV" etc.
2. I've put an AirPlay icon in the menu bar, but when I click on it, I see a greyed-out "AirPlay:" that constantly switches back and forth between "AirPlay: Looking for TV..." and "AirPlay: Off"
All help/thoughts appreciated!
    • By Will M
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By Lesbo
