LG 42LB650V Compatibility Query!
Hi All, I hope someone can point me in the right direction!
I offered to help a friend repair his LG 42LB650V 3D TV; it powers ON, the red light at the bottom of the screen comes ON, then it flashes a few times on pressing any channel on the remote and that's it. (I think the TV then switches OFF). NOTHING is ever displayed on the Screen and my friend assures me that the screen is working (& has not been bashed or broken).
I managed to get a 'broken screen' TV (again Model 42LB650V) and replaced the Power Board - no joy (behaves as before).
I wanted to then replace the Main Board BUT found out that the two TVs (despite having the same Model Number 42LB650V) differ!:
My friend's TV (the one I'd like to repair) Main Board has Markings: EAX65384004 (1.5) & EBT63439306.
The 'Broken Screen' TV has Main Board Markings: EAX65384003 (1.2), I think the other Part Number is EBT62383444.
The Two Main Connectors on the Main Boards are different!
I continue to try and find a cheap Main Board for sale but to date have not succeeded - I have found some for £75 - 100) but hope there is a cheaper option and I continue to search!
In the meantime I wonder if there is another workaround - i.e. is there a way that I can utilise the working screen TV but replace other parts (Main Board + Others) from the Broken Screen TV? Or, are the Screens also different and so my only option is to purchase an expensive Main Board?
If so, am I constrained to searching for that exact Main Board (eg. EAX65384004 (1.5) & EBT63439306) or are there additional boards that are compatible?
I hope someone can please advise me?
Thank you.
    • By Raymond Allinson
      I'd like to know if my LG TV  49UJ630V-ZA  4KHDR TV is compatible with ITVX as the icon seems to have disappeared, (presumably it was renamed ITVX).
      Can anyone help?
    • By Robert Viola
      Hello LG tv owners. Just got a 2024 LG UHD 50" tv. Model # 50UT7570PUB. The remote supplied with the tv isn't as good as my other LG tv Magic remote. Does anyone know which model Magic remote will operate my new tv correctly? Thanx.
    • By Marco Marcellino
      Since a couple of years I convert my pictures from raw on Google's format more efficient of JPG (about 30% less with the same quality) is a format natively used by google (home page, g+, images search, facebook and all Android devices (from 4.0 version) as well as supported by browsers chrome, Opera and early from Firefox. I'd like webOS inserts the native compatibility to decode this format of images. Thanks!
    • By MEA
      Hi, I'm looking for a pair of Bluetooth headphones to use with an LG 65sm8600pta TV. A lot of headphone reviews talk about the importance of the aptx standard/codec in making sure there is no lag in audio and to keep the picture and audio in sync. The manual for my TV says only that it supports LGs proprietary 'sound sync' standard. I can't find any headphones that have that compatibility. Does anyone know if LG TVs support aptx, and if not, what is the best way to make sure I don't spend $300 on good over ear headphones but I can't get them to sync?
    • By MphilDC
      Seeking guidance for an LG TV query. Could the LG37LH265H possibly have an IP address? Unlikely but would still inquire.
      Would want to leverage an Android phone for an extra remote.  No IP on the back of the set. Informed guidance sought.
