WP Central
What do you think of when you think of a taskmaster? You think of someone that constantly challenges you to do a certain task. You can picture someone who cracks the whip driving you to meet results for a specific deadline. They push you and push you, and usually show no mercy. But lucky a developer by the name of Rashi has made such issues a little easier to handle.
, originally made for webOS smartphones, takes list making to another level. Sure there are other task or note taking apps available for webOS, but what this does specifically, especially if you have an a Type-A personality is define those details. Right down to costs, time, and date associated with the chore. And it works.
a2t.imggaZt94jIdMM
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
