PicrossPicross is a fun and addictive game by PenduinBits that challenges you to solve picture puzzles (or picture crosswords, as the app name indicates) on an 8x8 grid solely using number clues that indicate how many blocks you need to fill in on a given row or column of the grid.  For $0.99, you get 384 unique puzzles that the developer created split between Easy, Medium and Hard levels. But what happens when you solve all 384 puzzles? The only option you have right now is to create your own puzzles using the Builder feature that lets you create and name up to 64 more of your own custom puzzles.
However, if you think you have created some great puzzles and want to submit those to the developer for a possible future update of the app, PenduinBits included a little easter egg that will send him an email with your custom puzzles.
  1. From the main homescreen of Picross, tap the "Options" button
  2. Go to the "Credits" tab and double tap on "Jacob Cappell" in the "Puzzle Design" section
  3. Go back to the "Options" tab and you should now see a "Submit Custom Puzzles" button
  4. Tap that button and an email will open up with all your custom puzzles in the body of the email
  5. Each puzzle will be enclosed between { } brackets, so if there is any puzzle you don’t want to share, just delete it from the body of the email
  6. Once you are happy with the puzzles to share, send off the email
There is no guarantee that he will use your puzzles for a future update, but if enough people submit their custom puzzles, we might just see a "community puzzle" update sooner, rather than later
is available in the webOS App Catalog for $0.99 and is compatible with all webOS devices running webOS 1.4.5 or higher
a2t.imggYqpWUzVe_o
    • By Jean Fiorin
      Good Morning, There is a recommended minimum distance between the TV and the viewer. I bought an LG OLED C155 last month and it is uncomfortable from a distance. It was my mistake. I bought it without worrying about visual comfort. Is it possible to reduce the screen's usable area to simulate a screen size TV of 48 inches or less, accepting the black borders that would be created? It would be something similar to a custom aspect ratio. The idea would be to be able to simulate a smaller screen size than the purchased equipment. other-bigger->65->55->48->other-less
    • By watchTV
      On my LG 49UN71 my custom input title and icon resets if I ever disconnect the HDMI cable. Can you make it so this doesn't change regardless what happens to the actual connection? See this post for more info:
    • By Packrat
      The SmartShare (on win10) using the Video Player work great!!! Thanks to the LG+WebOS team.
      Seems the Video player app doesn't support the full srt "standard".
      If there is better place to post or file bugreports please let me know.
      I was watching a mkv with a srt and that works great but it seems that some of the SRT codes are not implemented.
      Could support be added, or alternately just drop the codes so they don't show up on screen? ( Open curly "a" and a number and close curly bracket)
        {\a3} Details are below.
      Frank
      -------snip snip----------------
      WebOS: 05.10.25 (or tv fw?)
      TV: 65UM7300AUE NA model (please keep making real 4K IPS screens)
      SmartShare V2.3.1712.1201
      Reference for SRT codes:
      link hidden, please login to view   {\a3} (indicates that the text should start appearing on line 3)
    • By Moon
      How can I set a custom screen saver? Or a group of pictures/videos to cycle through?
    • By namary
      People usually convert the ringtone sound at which part of the iphone phone
      That confused me and didn't know how to fix it. Everybody
      Can you help me?
